WANTED - SPARK PLUGS FOR 2001/2 MUSTANG COBRA
Author Topic: WANTED - SPARK PLUGS FOR 2001/2 MUSTANG COBRA  (Read 3445 times)
Offline Giffo
  • LIFE IS A MUSTANG
  • Name: Steve G
« on: June 15, 2019, 08:23:16 pm »
Hi fellas and Gals. Who in Oz sells Motorcraft Spark Plugs for the 4.6 DOHC engines in the 2001/2002 Mustang Engines?
Part number SP433 Motorcraft.
Big Al do you stock them?
Or is there someone else?
Cheers all....
Re: WANTED - SPARK PLUGS FOR 2001/2 MUSTANG COBRA
« Reply #1 on: June 15, 2019, 08:48:22 pm »
Do yourself a favour and fit NGK plugs ,much better plug . Do a cross reference motorcraft SP433 to NGK .
« Reply #2 on: June 16, 2019, 09:42:07 am »
Would imagine they're the same ones for a 5.4L DOHC Australian modular motor?
Offline Giffo
  • LIFE IS A MUSTANG
  • Name: Steve G
« Reply #3 on: June 16, 2019, 10:19:24 am »
Thanks for the reply.
I have found the NGK ones. You speak to owners in USA and they mostly state stick to Motorcraft ones as the NGK have generate more heat. But I might try them. TR6 or TR55. Will have to do some more research.
What you reckon Jeff?
« Reply #4 on: June 16, 2019, 11:04:09 am »
Americans use motorcraft ,Aussies use NGK . Just platinum plugs should be fine and last 100,000 klms .  Just make sure they are the same heat range . If you want motorcraft you might have to get them from the states .
Offline Giffo
  • LIFE IS A MUSTANG
  • Name: Steve G
« Reply #5 on: June 16, 2019, 02:02:31 pm »
Thanks Glenn. NGK it will be, just have to work out which ones...
« Reply #6 on: June 17, 2019, 09:35:21 pm »
NGK are what you want.
« Reply #7 on: June 18, 2019, 02:25:31 pm »
Anything with a rare-metal electrode would be fine. Check out the mainstream manufacturers and go from there...
