Diff and trans oils
Author Topic: Diff and trans oils  (Read 2857 times)
Offline Dingo80
Diff and trans oils
« on: October 27, 2018, 09:22:30 am »
With the sales on this weekend going to stock up on oil ready for my build. Can't remember the oil I put in the my diff last time. Diff is a 9" with 3.55s and limited slip, running 31 spline axles. I like penrite oils but not sure whether to use 80W-90 or 85W-140.
Also got a C4 that the converter would now be pretty empty so will have to replace it all. C4 with 2500rpm stall and stage 2 shift kit. Which oil should I use here and does anyone know capacity? Semi full synthetic oil. I am a bit confused. Gearbox is behind an approx 400+HP 351W.
Thanks in advance.
Re: Diff and trans oils
« Reply #1 on: October 27, 2018, 09:43:24 am »
If its an LSD you'll need and LSD oil if its a truetrack any oil will do, Penrite is all ok for normal LSD, if you are not flogging it all the time 90 is fine but 140 if you flogging it ,
« Reply #2 on: October 27, 2018, 09:48:56 am »
Non synthetic type f or old style dexron is fine for the trans.
Offline Dingo80
« Reply #3 on: October 27, 2018, 09:54:26 am »
« Reply #4 on: October 27, 2018, 10:06:45 am »
The auto needs ATF 33 type F
and the diff 80-90  the 75-80 is a trans axle oil but this is suitable for Top loader
Offline Dingo80
« Reply #5 on: October 27, 2018, 10:13:00 am »
Ok cool I got it now. Found this
https://www.repco.com.au/en/brands/penrite-oil/penrite-atf-33-type-f-automatic-transmission-fluid-4l/p/A9336055
Would 4l be enough to fill a converter and the trans?
« Last Edit: October 27, 2018, 10:14:51 am by Dingo80 »
« Reply #6 on: October 27, 2018, 11:06:28 am »
Which one of these for trans do you reckon. Just the 75W-80 trans gear?
https://www.repco.com.au/en/oils-fluids/engine-oils-fluids/gear-oils/c/1862918080?q=%3Arelevance%3ApartSlot%3AGEAR%2BOIL%2BAUTOMATIC%2BTRANSMISSION&text=#
yup, none of those are for an automatic trans.
or if you want firmer shifts
« Last Edit: October 27, 2018, 11:15:30 am by barnett468 »
« Reply #7 on: October 27, 2018, 03:54:59 pm »
Quite a bit more than 4 lt for trans and converter . Once you have 4 lt in run through the gears so the fluid goes right through the box so you can get the correct level on the dip stick . Best way to check the level is in drive not park .  The fluid has to be pumped around and into the converter before the correct level will be shown on the dip stick .
Offline Dingo80
« Reply #8 on: October 27, 2018, 05:06:27 pm »
Cool thanks. Got 4l for now. Can always get more later.
« Reply #9 on: October 27, 2018, 05:20:38 pm »
it takes around 8 or 9 but not all at once.
http://www.tciauto.com/tc/fluid-capacity/
