The TFI module on the distributor had problems with heat soak. Symptoms were shutting of when hot and not starting when hot. Once cooled down they would work again. After a class action against them, Ford USA moved the TFI off the dizzy and onto the engine bay panel. At the same time Ford AUS went to coil packs, so you won't see any falcons with the relocated TFI. I would firstly get a new TFI module from rockauto, a genuine Motorcraft one. Another option is the TFI relocation kits you can get like the one from McCully racing. Of course, it may not be this, but worth a shot. Google TFI Mustang problems and you'll read tons about it.
