OK, I've now started rebuilding the front end of my '69 Mach 1 and will need some help from those of you who may have already done the hard work in working out what bits here may be the same as Aust. built vehicles.
I already have the spring carriers and bushes and I have been told that the top ball joints are the same as the XF, the lower control arms I will buy as one with the lower joint with bushes fitted. The outside tie rod end I will need to source, idler arm and/or bushes and hub bearing sets/seals.
Can anyone help?>
Thanks Mac.
