anybody in AUS sell a 1/2" fuel sending unit
Author Topic: anybody in AUS sell a 1/2" fuel sending unit  (Read 3495 times)
Offline zlat347ci
  • Name: Zlat
« on: August 14, 2017, 10:00:49 am »
Anybody in AUS sell a 1/2" fuel sending unit?
Found these in the US which look good.
http://www.robbmcperformance.com/products/1084_fordsend.html
Offline boofhead
Re: anybody in AUS sell a 1/2" fuel sending unit
« Reply #1 on: August 14, 2017, 05:16:11 pm »
modify your current one - easy job
« Reply #2 on: August 14, 2017, 07:36:13 pm »
Or put a sump on your tank thats my plan
Offline zlat347ci
  • Name: Zlat
« Reply #3 on: August 15, 2017, 09:05:35 am »
could you do it with just a -8 bulkhead style fitting or would you need to replicate the factory pickup tube and get that welded in?
« Reply #4 on: August 15, 2017, 10:30:14 am »
Offline lukep6470
« Reply #5 on: August 15, 2017, 01:53:07 pm »
Tig this into the back of your tank
https://www.summitracing.com/int/parts/cee-4041/overview/
Looking south for the fireball in 3,2,1....
« Reply #6 on: August 15, 2017, 02:05:08 pm »
That's what i'm using, new tank though!
Offline boofhead
« Reply #7 on: August 15, 2017, 08:17:07 pm »
braise the tube in.
Offline zlat347ci
  • Name: Zlat
« Reply #8 on: August 16, 2017, 07:28:16 am »
My float had a pin hole so need to change anyway bought the one from the US has a return line provision so will come handy later on down the track.
What power should people upgrade to 1/2" setup?
« Reply #9 on: August 16, 2017, 08:03:34 am »
Over 700HP . 3/8 line is fine for street cars under 700 HP . Different story for a track car as they will run a 1/2 inch line but with the best electric fuel pump  or pumps with return lines and the best fuel system and filters . The problem with the 1/2 inch line is the G force pushing the fuel back to the tank and that's why you will need a big electric pump and a top fuel system to match .  Run a fuel pressure gauge you can see and watch at high revs and a fuel ratio meter as well . Stock 65/66 mustangs use a 5/16 fuel line other than the GT models . Ford changed to a 3/8 line in later years for most models .
Offline zlat347ci
  • Name: Zlat
« Reply #10 on: August 16, 2017, 08:42:50 am »
ive got 1/2" braided line all the way, my bottle neck was the fuel sender at 3/8, am i wasting my time getting this 1/2" sender to match?
« Reply #11 on: August 16, 2017, 08:52:47 am »
If you have 1/2 inch line through the car do the rest . You want good volume and low pressure with a carby .  Just make sure your pump can Handel the 1/2 inch line and a good return line .
Offline zlat347ci
  • Name: Zlat
« Reply #12 on: August 16, 2017, 09:28:30 am »
i run a Holley HP series 170GPH, worked really well with the combo. Constant 6.9psi on dyno runs back to back
« Reply #13 on: August 16, 2017, 10:01:00 am »
Yep that's on a dyno run ,different story on a drag track . No G force on a dyno .  You are running a return line aren't you ? . If not you pump won't last ,it will over heat .
Offline zlat347ci
  • Name: Zlat
« Reply #14 on: August 16, 2017, 12:08:11 pm »
no return line at the moment, (mechanical pump)
« Reply #15 on: August 16, 2017, 12:59:35 pm »
Ok see it goes .  With a 1/2 inch line we usually run an electric pump at the back ,pushing the fuel .  You won't know till your on the strip and watching the gauges . As I said different story on a dyno just ramping the power on .
