289 rebuild options
Author Topic: 289 rebuild options  (Read 3773 times)
Offline Bangers77
289 rebuild options
« on: May 12, 2017, 05:01:14 pm »
Hey guys,
Ive got a mate who is about to rebuild his motor.
He's looking for a nice streetable motor around 300-325hp
Starting fresh using existing 289 virgin bore.
Pistons, compression ratio, heads intake cam carby. If anyone can recommend a tried setup that would be great
It's going in front of a 5spd manual.
Budget of around 5g for parts as we will be doing the labour ourselves
All advice appreciated
Cheers Mark
Cheers Mark
Offline boofhead
Re: 289 rebuild options
« Reply #1 on: May 12, 2017, 05:44:59 pm »
I am keeping the budget in mind as well as the target hp.
1) ebay find a second hand good condition 28oz 302 crank and rods.
2) Set of flat top pistons (I have a set of forged TRW pistons and rings here if interested 30 over).
3) ARP rod bolts.
4) ebay a new set of e-street heads - 170cc 190 intake valve
5) Flat tappet - Lunati Voodoo 61001 camshaft
6) Edelbrock RPM manifold, 650 Holley, half inch open spacer (find second hand and ebay)
+ the rest
I would deck the heads to 58 cc but that is extra cost.
There is a start....
« Last Edit: May 12, 2017, 05:49:50 pm by boofhead »
Offline Bangers77
« Reply #2 on: May 12, 2017, 05:59:07 pm »
thanks boofhead
ill pass this info onto him.
Cheers Mark
« Reply #3 on: May 12, 2017, 09:14:24 pm »
Agree with Boof's advice.
Offline Gastill
  • Old Boy
  • Name: Greg
  • Car: 66 K Code
« Reply #4 on: May 12, 2017, 09:55:56 pm »
I agree that setup, my setup is similar
Running 650 quicktime carby, pacemaker headers
Went onto calibrated Dyno and ran 325 HP and 335 Nm at 6400 rpm
The smell of burning rubber reminds me of losing my virginity.
Offline mk1_oz
« Reply #5 on: May 13, 2017, 04:51:02 pm »
What's a standard 289 rated at?  I forget.....
Offline BAC
  • Name: Brian
  • Car: '71 M code auto
« Reply #6 on: May 13, 2017, 05:12:52 pm »
Depends on year...
Brian
« Reply #8 on: May 18, 2017, 01:46:18 pm »
spend the money to zero deck the block or don't bother building a hi perf engine.
make it 10.5:1 compression
i would also use .035" thick cometic gaskets but they are pricey.
3.50 gears
drill a .020" hole in both front cam oil galley plugs
use a cloyes true roller timing chain or red rollmaster
use a cheap chinese hi po damper
get it balanced.
msd anti vibration ignition coil.
plug the distributor vacuum advance.
comp cams xe268h can is decent also and might be cheaper than the lunati.
arp or similar good oil pump drive
you can buy eagle i beam rods for around the same price it will cost to install arp rod bolts in your stock ones.
good 3 row radiator with a high density core.
1717p flex a lite mechanical fan with shroud or oem electric fans with a fan controller.
high flow milodon 180 degree t stat.
14 - 16 lb rad cap.
crane anti pump lifters or crower cool face cam oiler lifters.
remflex gaskets with 1 1/2" or 1 5/8" headers.
magnaflow mufflers
double pumper carb.
1/2 grooved main bearings.
« Last Edit: May 18, 2017, 02:05:25 pm by barnett468 »
Offline boofhead
« Reply #9 on: May 19, 2017, 10:02:17 am »
A lot of the early 289 blocks have the oil feed to the trust plate / timing chain blocked - pull that small welsh plug out. The extra 30thou hole is a good idea as Barn details.
Also use a 2 piece real seal - pull rope seal pin out.
Offline Bangers77
« Reply #10 on: May 19, 2017, 08:36:17 pm »
thanks heaps for your input guys, I'm passing this all on to my mate
Cheers Mark
