Hi, I've always liked the CS,331,347, lighter, which is better for your front end, and car balance
What do you think of crate engines? Or can anyone in the forum recommend an engine builder whose credible ?
So 347 is great combo, particularly if your early block is ok as they are stronger then the later 302 block, a good 347 will make mid 400hp and be perfectly street-able. The rotating assemble is lighter then a 351 and the mains bearings are smaller so less heat and friction than a 351. 351 is bigger heavier and stronger but I wouldn't consider one unless going to a 408 stroker. You could make a 347 look almost stock in the bay. Talk to Ian Woodward at Fataz racing in Brisbane tell him Shaun sent you. Or if you want talk about what to build I'm happy talk about options. Boofhead on this forum has 347 kit for sale as it happens. below is my 347, which is likely more than you need, you could get away with cheaper heads depending on the HP you want
Unless your after more than 500hp the 347 is the best engine. Otherwise a 351 stoked to 408 is the go. I would personably never build a plain 351w performance engine as a 347 will be better in all areas.I do have a 347 kit plus cam plus heads I was going to build for my mustang but change of circumstances so willing to sell it off. PM if serious.
Sounds good,thanks for the info...I didn't know about the block strength. Has boofhead got the kit advertised on another forum? Sorry I'm new to the whole forum thing,so need a bit of direction.Fataz seems to be the common recommendation,so I'll go with them by the sounds of it
Header change ,depends on what you have . If your going to build a 347 that's great but what HP are you chasing ? Mild to wild ? You did say just some more HP . Your top loader will be fine but yes the clutch might be a problem . With a good HP increase you will spin one wheel unless you fit a true trac diff . My 347 is around 430 HP at best and that's plenty on the street .
What headers do you have now is the question. You would balance it with a new clutch anyway
I'd be going for a mild setup, not chasing crazy hp
Exactly shaunp, and it gives me a decent base to improve on
Your car being a manual ( factory) your diff ratio might be ok . Might be a 3.00 :1 ratio or even a 3.25 type ratio . Do you know what it is ? . Going from around 200 HP to around 400 HP will put a smile on your dial .
Your model mustang only comes with the small Windsor so you could make it look std looking if that's what your after or look like a hi performance engine
