Gilmor Drive Gears
Author Topic: Gilmor Drive Gears  (Read 8065 times)
Offline 65tang
Gilmor Drive Gears
« on: March 11, 2008, 05:22:59 pm »
Was look at a set and belt for a gilmor drive today,  has anyone got any experience about these and how do they work, are they easy to install.  what are the good and bad points about them.  Cheers
289 66 Coupe White (for sale)
289 65 Coupe Red
Wanting 65/66 Fast Back
Offline Brett_T
Gilmor Drive Gears
« Reply #1 on: March 11, 2008, 07:55:39 pm »
Easy to install, I just liked how they looked, and the noise they made..   only bad point i found was make sure you carry a spare belt...
Offline shelby_mustro
  • Name: Ryan
Gilmor Drive Gears
« Reply #2 on: March 11, 2008, 09:24:12 pm »
The only bad thing I’ve herd about them is that the Gilmer drives can be little bit harsh on the bearings for your water pump and your alternator but other than that they are petty sweet.
When I get enough $$ ill be sure to put one on my 302w  :p
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
1966 mustang convertible nightmist blue
1951 f1 chopped truck blown c4 black
1963 Xl falcon ute 200ci 3spd manual white
Offline whiplash
Gilmor Drive Gears
« Reply #3 on: March 19, 2008, 05:36:49 pm »
THEY CHEW BELTS IF TO TIGHT AND THROW EM IF THERE TO LOOSE !!!NOT WORTH THE HASSLE
Offline Brett_T
Gilmor Drive Gears
« Reply #4 on: March 20, 2008, 06:31:51 am »
I only had one drama. and that was that the company that re-coed my alternator did not tighten the nut !! hence loosing a belt. other than that i didnt have any hassles whiplash.. and i run one for 15 months;_
Ryan. i will have that set back next week if you are keen on it...
Offline 69mach1
Gilmor Drive Gears
« Reply #5 on: March 20, 2008, 08:19:57 am »
I run the Gilmer setup on my engine, one advantage is there is no belt slippage, only thing is if all the pulleys aren't lined up so the belt runs straight then all that torque is put on one side of the belt causing it to snap. I carry a spare which costs $59.
  • Name: Ryan
Gilmor Drive Gears
« Reply #6 on: March 20, 2008, 11:40:35 am »
Yea Brett ill give it a go! ;_ Just keep it safe for me untill next time I see you :(
t5 5 speed manual
Other cars
Offline Brett_T
Gilmor Drive Gears
« Reply #7 on: March 21, 2008, 09:12:22 am »
Yeah I used to carry a spare, but then again, doesnt everyone these days driving an old car.. I mean  not many ladies wear pantyhose anymore  :_:+
