'67-'68 Turn Signal Switch
Author Topic: '67-'68 Turn Signal Switch  (Read 1877 times)
Offline BAC
  • Name: Brian
  • Car: '71 M code auto
« on: July 30, 2016, 05:52:52 pm »
Fixing the horn on my '68 Cougar and some numb nuts has pulled out the horn wiring to the turn signal switch.
Everything else on the switch works perfectly, only need the two spring loaded lugs that contact the back of the horn ring:
Hoping to avoid spending $130 on a whole new switch just to get those two little pieces.  So if you have an old clapped out or broken switch that still has the lugs I would be happy to take it off your hands...
« Last Edit: July 30, 2016, 05:54:32 pm by BAC »
Brian
Offline BAC
  • Name: Brian
Re: '67-'68 Turn Signal Switch
« Reply #1 on: July 30, 2016, 09:14:20 pm »
A '65-'66 switch would also do as I believe the bits I want are pretty much the same.
Brian
