Here is another one:
347 ,11.5 comp , 1.7 rockers
Edelbrock Victor Jnr alloy heads
Trick flow R series box intake manifold
75mm throttle body
80mm mass air and 30lb injectors
Valve Setting: Intake .020 Exhaust .020 HOT
Lift: Intake @Cam 420 @Valve 672 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 420 @Valve 672
Rocker Arm Ratio 1.60
Cam Timing: TAPPET @.0205
Lift: Opens Closes ADV Duration
Intake 37.0 BTDC 67.0 ABDC 284.0 °
Exhaust 76.0 BBDC 34.0 ATDC 290.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99885
Loads Closed 215 LBS @ 1.950 or 1 61/64
Open 592 LBS @ 1.320
Recommended RPM range with matching components
Minimum RPM 3600
Maximum RPM 7400
Valve Float 8000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 22.0 BTDC 50.0 ABDC 103 252.0 °
Exhaust 61.0 BBDC 17.0 ATDC 113 258.0 °
