Hi Rox
Got another one for you.
450ci, AFR 225 heads, 12.5:1 comp, super victor manifold, 1050 dominator, solid roller
Valve Setting: Intake .020 Exhaust .020 HOT
Lift: Intake @Cam 420 @Valve 672 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 420 @Valve 672
Rocker Arm Ratio 1.60
Cam Timing: TAPPET @.0205
Lift: Opens Closes ADV Duration
Intake 42.0 BTDC 76.0 ABDC 298.0 °
Exhaust 87.0 BBDC 41.0 ATDC 308.0 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99885
Loads Closed 215 LBS @ 1.950 or 1 61/64
Open 592 LBS @ 1.320
Recommended RPM range with matching components
Minimum RPM 4600
Maximum RPM 8000
Valve Float 8600
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 27.0 BTDC 59.0 ABDC 105 266.0 °
Exhaust 72.0 BBDC 24.0 ATDC 115 276.0 °
