I'd forget the flat tappet solid and put a roller hydraulic in it, like a comp cams XE274, Airgap intake and some 165/185 AFR heads. 650 double pumper and a 3.25-3.5 truetrack behind the toploader, there is no point in flat tappet cams anymore other then to save a couple of bucks, haven't used one in years. A roller cam makes for a much nicer engine to live with and faster, more reliable to boot. E street heads are an inexpensive entry level head, dont flow that well cheap valve parts that need swaping out.
