Ok, here ya go, and you must follow the instructions exactly this time . I am trying to achieve the impossible here.
Order the distributor clamp from Ebay or a speed shop or get a chrome one from Super Cheap as soon as possible . When using the correct clamp, the bolt should only have a lock washer on it.
Make sure the distributor bolt is tight.
Put your new 5 qts of oil and filter in.
Make sure you have enough gas.
YOU NEED TO DO THE FOLLOWING EXACTLY HOW IT IS DESCRIBED OR IT WILL BE USELESS AND YOU WILL HAVE TO DO IT AGAIN AFTER THE ENGINE HAS NOT RUN FOR AT LEAST 4 HOURS SO DON'T SCREW THIS UP.
1. Turn the fuel mix screws on the base of every carb, in [clockwise] EXACTLY 1/4 turn . Do not turn the idle setting screws or you will be very, very, unhappy.
2. Put your video camera in the car then turn the camera on.
3. Push the gas pedal down 1/2 way then let it up.
4. Push the gas pedal down 1/8th of the way and hold it there.
5. Turn the key to start it . Do NOT pump the gas pedal or remove your foot from it while turning the key.
6. After it starts and runs for only 5 seconds, remove your foot from the gas . If it dies, restart it and keep the idle up for 30 seconds, then let your foot off the gas pedal.
7. If it idles, let it idle for a total of 30 seconds only . After this, quickly stab the gas pedal 1/2 way to the floor as fast as you friggen can then instantly let it up . It "should" die or almost die before it revs up so don't worry if it does . If it dies, simply restart it then go to step 8.
8. Take the same video you did yesterday of the engine and the exhaust at idle but try to get behind the car if you can this time.
9. After this, shut the video off and let it idle for 5 minutes.
10. After 5 minutes is up, look at the exhaust to see if it still smokes.
11. Next, get in the car and stab the gas pedal 1/2 way to the floor as fast as you friggen can then instantly let it up . It should have less hesitation now then it did when you first did it and it should not die . If it does, we can fix it.
12. Post the video.
