Author Topic: Do you have to degree a new cam ?  (Read 490764 times)
« Reply #175 on: February 24, 2016, 05:58:13 pm »
Safer to screw the bolt back in a little and let the puller hit on that . The balancer hasn't been on for that long so it should come off easy . Sometimes if you have a lot of pressure on the puller hit the balancer with a rubber hammer  and it might shock off .no heat
« Reply #176 on: February 24, 2016, 06:03:15 pm »
Tried the bolt but it just starts winding the crank bolt back in
« Reply #177 on: February 24, 2016, 06:04:47 pm »
take the f'n crank bolt out . never, ever use a pointy thing on the crank bolt.
« Reply #178 on: February 24, 2016, 06:06:22 pm »
I was smart enough not to do that, man give me some credit  :lmao:
« Reply #179 on: February 24, 2016, 06:08:30 pm »
you just said the crank bolt was turning in
you need to STOP right now
« Reply #180 on: February 24, 2016, 06:09:41 pm »
Romac 's can be tight. the way to get it off is take the load on the center bolt then shock it by hitting the center bolt with a big hammer, tighten the bolt and hit it again etc
« Reply #181 on: February 24, 2016, 06:11:37 pm »
remove the puller.
hold the crank bolt up to the pointy thing.
the outside of the pointy thing must be BIGGER than the outside of the crank bolt . If it is NOT, say goodbye to the threads in your crank.
this is a pointy puller . do NOT use this puller on the crank bolt if the head of the pointy thing swivels around
this is a flat end puller . you can use this on a crank bolt but the crank bolt may still screw into the crank as you turn the puller bolt
« Last Edit: February 24, 2016, 06:16:49 pm by barnett468 »
« Reply #182 on: February 24, 2016, 06:16:26 pm »
remove the puller.
this is a flat end puller . you can use this on a crank bolt but it may still screw into the crank as you turn the puller bolt
Right, the top pic is exactly how i have it and it move at all.
« Reply #183 on: February 24, 2016, 06:17:26 pm »
For all the time and effort of everyone involved probably would have been worth paying the $2500 at this rate.
As soon as i saw it turn i stopped
« Last Edit: February 24, 2016, 06:20:05 pm by Fitzy1980 »
« Reply #184 on: February 24, 2016, 06:19:43 pm »
as soon an you saw what turn?
is the pointy thing bigger than the crank bolt?
did you remove the crank bolt?
you can fuk your crank up easy if it is not correct.
« Reply #185 on: February 24, 2016, 06:21:45 pm »
I have a tap to retap the crank thread. Not expensive use it often.
« Reply #186 on: February 24, 2016, 06:30:17 pm »
When this thread is added to the earlier one about webers that wouldn't stay in tune but turned out to be a stuffed distributor gear and cam, I reckon this engine has set a new record for the number of pages generated on this forum.
I admire your preparedness to have a go at this. Good luck!
« Reply #187 on: February 24, 2016, 07:08:10 pm »
turns out best part to use was the larger flat piece.
Balancer is 3/4 of the way off. But seems to have hit this point and is really hard to turn.
normal ?
« Reply #188 on: February 24, 2016, 07:10:16 pm »
 :lmao: :lmao:
Cheers mate,  i figured with Barn offending everyone  :bolt: i'd give ya's all a bit of entertainment.
I dont normally give up on things but this is really pushing the limits of my sanity  :ouch:
« Reply #189 on: February 24, 2016, 07:15:18 pm »
normal ?
if the crank damper bolt is out, keep turning the puller bolt.
if you left the crank bolt in, the damper has bottomed out on the washer on the damper bolt.
as soon as the puller bolt gets easy to turn, hold the puller as you turn the bolt because the damper will soon fall off.
« Last Edit: February 24, 2016, 07:20:04 pm by barnett468 »
Offline trav68
« Reply #190 on: February 24, 2016, 07:18:38 pm »
Not normal, should get easier as more of it dis-engages from the crank.
« Reply #191 on: February 24, 2016, 07:23:18 pm »
Yep only a ten minute job if that
« Reply #192 on: February 24, 2016, 07:25:14 pm »
 :lmao: :lmao:
 :shrug: I haven't even started yet.
You are also the one whom seems to be having a lot of trouble getting the Snausage out . I can assure you that I can easily get mine out any time I feel like it .   :thumb:
No comment .  :lmao:
« Reply #193 on: February 24, 2016, 07:25:59 pm »
What are you trying to say Glenn ?  :toetapping:
 :lol:
« Reply #194 on: February 24, 2016, 07:28:05 pm »
 :lmao:
« Reply #195 on: February 24, 2016, 07:30:58 pm »
Is that before or after we spent an hour trying to explain to him how to do it? .  :lmao:
« Reply #196 on: February 24, 2016, 07:32:14 pm »
Feel like the first man to first discover fire  :pepper:
I need a beer and a lie down  :thud:
« Last Edit: February 24, 2016, 07:35:49 pm by Fitzy1980 »
« Reply #197 on: February 24, 2016, 07:38:12 pm »
These are Snausage lifters . Grab the roller and make sure it rolls smoothly and that there is NO play in the roller . If there is ANY play in the roller, it is junk.
« Reply #198 on: February 24, 2016, 07:42:07 pm »
10/4
Just putting the tin lids to bed and im all over it.
« Reply #199 on: February 24, 2016, 07:42:41 pm »
FOSTERS LAGER...If it's good enough for a Roo, it's good enough for you!  :thumb:
