Author Topic: Do you have to degree a new cam ?  (Read 488158 times)
« Reply #125 on: February 23, 2016, 09:07:15 pm »
http://www.compperformancegroupstores.com/store/merchant.mvc?Store_Code=CC&Screen=PROD&Product_Code=435M
https://www.semashow.com/sites/default/files/comp_cams_melonized_distributor_gears.pdf
Those have to be photos of their cast gears even though it says melo, because they look so crappy . If that's really their melo gear, I wouldn't use it.
Ok, I just looked and they look the same as the MSD gear so those are their melonized ones.
« Last Edit: February 23, 2016, 09:15:07 pm by barnett468 »
« Reply #126 on: February 23, 2016, 09:19:59 pm »
Mallory have been selling most distributors with Melo gears for a couple of years.  I see Crane make Holden small block gear as well which is handy to know. A mate wants to build a Blue meanie VK commodore with a 355, & injected VN heads
« Last Edit: February 23, 2016, 09:26:44 pm by shaunp »
« Reply #127 on: February 23, 2016, 09:32:05 pm »
Hey Barnett a 355 vn headed engine ,cool hey .
« Reply #128 on: February 23, 2016, 09:46:10 pm »
I have absolutely no friggen idea what the hell that is, and does VN stand for Very Nice .  :lmao:
« Reply #129 on: February 23, 2016, 09:55:45 pm »
VN heads ,thought you knew everything ,google is your friend  :grin:
« Reply #130 on: February 23, 2016, 09:57:32 pm »
VN is the model ID for a Holden commodore, it was the first year of high port heads on the fuel injected 308 small block. They are pretty sort after for 308 engines work pretty well, kind of hard to come by, other than that the early 70's pre smog heads are the next best fitted with Torana L34 valves, which is the same as the Formula 5000 open wheel Holden engines used. A 308 is not like an SBC, it kind of a cross between all GM small blocks
« Reply #131 on: February 23, 2016, 10:05:34 pm »
Gee thanks Shaun  :thud:  was hoping Barnett would have know idea what we were talking about .   :smile01:
« Reply #132 on: February 23, 2016, 10:51:58 pm »
looks like i dont use it as much as some thought .lol . and i still have no idea what he ia talkin about
« Reply #133 on: February 23, 2016, 11:14:57 pm »
He is talking VN  model heads from a V8  5lt  :grin: .
Offline Fitzy1980
« Reply #134 on: February 23, 2016, 11:15:50 pm »
So much to take in... :ouch:
Comparing the current cam with say the suggested Comp cam, would it be more than likely they would have used stiffer springs?
Everything else seems to be high dollar parts so i cant see logic in scrimping on the springs etc.
« Reply #135 on: February 23, 2016, 11:22:05 pm »
No not likely,  but you have to get the cam specs and spring specs for both cams . You might have to get the installed hight changed  .  This is very very important .
Offline Fitzy1980
« Reply #136 on: February 23, 2016, 11:22:25 pm »
Had a VN Group A SS back in the day.
Until i found the mighty blue oval and was saved  :bow:
Offline Fitzy1980
« Reply #137 on: February 23, 2016, 11:24:00 pm »
Ffs,  :lmao:
It took me over 3 weeks to just get that cam info from them  :ouch:
« Reply #138 on: February 23, 2016, 11:24:55 pm »
Its worth a few bucks now . The VN group A engine was a big deal for holden .
« Reply #139 on: February 23, 2016, 11:26:12 pm »
If you have the cam number you can find the spring specs without talking to them . The valve  spring pressures and installed hight have to be checked and correct .
« Last Edit: February 23, 2016, 11:31:02 pm by GLENN 70 »
« Reply #140 on: February 24, 2016, 05:05:09 am »
fitzy . read my posts . i have your cam specs . i know what spring pressures the new cam needs . both cams can use the same springs . . your  engine ran fine before .  your engine  is still new so your springs should be fine but ask them if they used their own springs or bought the heads assembled and tell us what they say . i have the spring rate for the assembled heads . they have two different rates . if your heads came with the lighter rate springs, it probably wouldn't rev past 5500 rpm and would miss and pop . do not loose sleep over the springs, you have enough going on  . this should be fun instead of  being stressful.
« Last Edit: February 24, 2016, 07:39:32 am by barnett468 »
« Reply #141 on: February 24, 2016, 07:44:03 am »
If you have the cam number you can find the spring specs without talking to them.
Unfortunately not in this case . Snausage has 3 optional lifts for the same cam number . The cams have a serial number that identifies them and only Snausage knows what the serial number means, however, the clowns sent Fitzy the lift for his cam yesterday so we now have all that info.
The cam I suggested has around .020" more lift and a slightly steeper ramp, so it is not dramatically different.
All I want now is a photo of his Snausage so I can see if it is steel or not . :lmao:
« Last Edit: February 24, 2016, 07:59:29 am by barnett468 »
« Reply #142 on: February 24, 2016, 09:57:27 am »
Check the spring diameter . If the idiots bought the heads assembled and you have the smaller springs, you are screwed because they are even too light for your Snausage cam.
If they bought them assembled and you have the bigger springs, they are perfect for your app and could support even a slightly bigger cam.
diameter 1.437 . closed 130 @ 1.800 . open 330 @ 1.25 . coil bind @ 1.08 . max lift 620
diameter 1.550 . closed 195 @ 1.900 . open 456 @ 1.25 . coil bind @ 1.08 . max lift 650
Offline Fitzy1980
« Reply #143 on: February 24, 2016, 11:52:14 am »
I'm heading home shortly and ill pull the cam and we'll go from there
« Reply #144 on: February 24, 2016, 12:04:15 pm »
oh boy, more fun!  :thumb:
Offline Fitzy1980
« Reply #145 on: February 24, 2016, 12:39:30 pm »
Ive had the morning of my life today, swear the gods hate me.  :lmao:
Mrs was on the way to the hospital. Rings and says the car has died, coughing, no power and just died. Now this is a 3 week old $90k 200 series Landcruiser.
Get there doesn't even look like starting, checked a few things. Then i get a really really bad feeling....
I ask "did you put fuel in on your way"
Her "yes"
Me " what fuel ?"
Her " just what i normally put in "
I keep all reciepts for tax purposes and there we have it big ol tank of 98 OCTANE !!!!!!  :ouch:  :ouch:
So its on a flatbed back to Toyota, and im prety sure there is no warranty for stupidity.
No wonder a man drinks..
Fml  :cry: :cry:
« Reply #146 on: February 24, 2016, 12:44:33 pm »
So what is wrong with using 98 octane....unless it's a diesel.
Look on the bright side, with your newly acquired mechanical skills, you should easily be able to replace the engine .  :lmao:
Offline Fitzy1980
« Reply #147 on: February 24, 2016, 12:53:34 pm »
Yes, V8 turbo diesel...
 :lmao: i can see this costing a bomb.  :cry:
Top it off she then wanted my car, not a chance.
Hyundai hire car for you champ  :lmao:
« Reply #148 on: February 24, 2016, 01:01:18 pm »
xlnt!
Well now that she knows to use diesel, perhaps she could put that in your gas powered car .   :thumb:
Hyundai hire car for you champ   :thumb:
ummm....better buy the additional insurance!  :lmao:
« Last Edit: February 24, 2016, 01:04:05 pm by barnett468 »
Offline Fitzy1980
« Reply #149 on: February 24, 2016, 01:13:32 pm »
xlnt!
Ahh see, have her covered there diesel nozzle is larger and wont fit :thumb:
« Last Edit: February 24, 2016, 01:15:26 pm by Fitzy1980 »
