351W 2 Barrel Cast Intake
Author Topic: 351W 2 Barrel Cast Intake  (Read 6546 times)
Offline mk1_oz
« on: November 26, 2015, 07:58:13 pm »
I need an original cast iron 2 barrel intake manifold for a 351 Windsor. Not sure of age of my engine - not sure if it makes a difference.
Prefer SA where possible
Offline BAC
  • Car: '71 M code auto
Re: 351W 2 Barrel Cast Intake
« Reply #1 on: November 26, 2015, 09:30:00 pm »
Ouch! Not many of those still around, I'd reckon - most would have been turfed 30 years ago...
Might have more luck finding a 4 barrel but I guess that wouldn't satisfy the inspectors?
Offline mk1_oz
« Reply #2 on: November 26, 2015, 10:10:02 pm »
Would the 2 barrel Autolite carby fit on the 4 barrel intake?  If so, I suspect the rego inspectors would not be able to tell the difference (they would not remove the carby)??
« Reply #3 on: November 26, 2015, 10:26:38 pm »
No you can not do that . Surly someone on here has taken off there 2 barrel carby intake manifold and carby to fit a 4 barrel and have it sitting around .  That's why I have one sitting around .
Offline mk1_oz
« Reply #4 on: November 26, 2015, 11:50:40 pm »
If nobody here has one (even one i can borrow) then I will search the interweb, feebay and gumtree.
Offline LEE H 69
« Reply #5 on: November 27, 2015, 07:29:17 am »
Think I have one in the shed at home, I will check for you tonight,
Offline mk1_oz
« Reply #6 on: November 27, 2015, 09:06:21 am »
 :thumb:
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
    • http://s731.photobucket.com/albums/ww313/ozzyone_photos/66%20GT350H/?albumv
  • Name: Dale
« Reply #7 on: November 27, 2015, 09:07:18 am »
give Jeremy a call at Image Classic Cars at Research Road  Pooraka 0412 075 064 he has a lot of gear and may possibly be able to help.
Paint by IMAGE CLASSIC CARS
build thread...http://www.mustang.org.au/forum/index.php/topic,14043.0.html
Offline mk1_oz
« Reply #8 on: November 27, 2015, 11:55:56 am »
OK I think I have found one but he want......... $250 for it!!!!!!!  Gulp......supply and demand.  Not happy.
Lee H 69 I won't grab this other one until I hear back from you (or any other forum members) just in case you do have one........
Offline LEE H 69
« Reply #9 on: November 27, 2015, 07:08:34 pm »
is this what you are after? it didn't come on my 351w but came with it, Absolutely no idea what they are worth or the freight to you from QLD, make me an offer if it's what you need,
Offline mert
« Reply #10 on: November 27, 2015, 07:38:10 pm »
C90E-9425-F = '69 351.... Looks like the right animal..
Offline mk1_oz
« Reply #11 on: November 27, 2015, 08:54:32 pm »
Appreciate you looking....yes that looks like the beast.  any idea of the weight so I can look into freight costs?  My uneducated guess would be 20kg.....
Offline LEE H 69
« Reply #12 on: November 27, 2015, 09:04:32 pm »
Yep spot on mate, 20Kg.    pick up would be from Logan Qld if that helps with costing
Offline BAC
« Reply #13 on: November 27, 2015, 10:18:20 pm »
E-go depot to depot service.  :thumb:
Offline Bluedog
  • GGT69
  • Name: Glenn
« Reply #14 on: November 28, 2015, 06:30:49 pm »
Mate they must all be in QLD, I have one you can have too. D70E-9425-BD.
But I think the freight will be the killer.
Offline mk1_oz
« Reply #15 on: November 29, 2015, 01:33:17 am »
Cheers.  Freight would be OK if I did not need one ASAP.  Overnight freight is $140+  ouch.
Hopefully the local one I found is ok else I will have to rob QLD of one!!!
Offline ND69
« Reply #16 on: November 29, 2015, 11:10:53 am »
Brian ,
Check your existing mounting bolt holes, some have 16 holes, usually on 4v heads,
others have 12bolts for  v2 heads
The extra holes can be drilled and sealed with short bolts.
Tip: When fitting use a four of long bolts with the heads cut off as alignment pins
ND
Offline dead66
« Reply #17 on: December 03, 2015, 01:37:40 am »
I have one and carby of the partners 68 model windsor, we replaced it with a 4 barrel manifold and carby and I would like to sell it for offers around $150 , I am sure I can get a fair postage deal on it to SA as I am in Bathurst.
« Reply #18 on: December 03, 2015, 11:00:06 am »
Dead 66 are you sure yours is a 351w and not a 289/302 set up .
Offline mk1_oz
« Reply #19 on: December 03, 2015, 01:12:35 pm »
Cheers all.  I now have a super heavy 2 barrel cast iron intake with 16 bolts.  Putting it on as we speak...
Offline 66 Hertz
  • Web Editor
  • Name: Dale
« Reply #20 on: December 03, 2015, 01:55:53 pm »
 :thumb: :thumb: :thumb:
Offline mk1_oz
« Reply #21 on: December 03, 2015, 03:51:35 pm »
Its on!!!!  Had to use the engine hoist as my back just wasn't going to cope with leaning into the engine bay with a 20kg boat anchor.  Will see tomorrow if I have any leaks.  I was pleased to see that the valley was almost spotless so this motor has not done alot of Ks since its last rebuild.
Offline LEE H 69
« Reply #22 on: December 03, 2015, 09:34:36 pm »
good to hear you sourced one local :thumb:
Offline mk1_oz
« Reply #23 on: December 03, 2015, 10:55:44 pm »
The weight difference between the Offy and the steel one is unbelievable!
