Brian ,
Check your existing mounting bolt holes, some have 16 holes, usually on 4v heads,
others have 12bolts for v2 heads
The extra holes can be drilled and sealed with short bolts.
Tip: When fitting use a four of long bolts with the heads cut off as alignment pins
ND
