Still no change to the stuttering, popping, ignition issues. In fact it seems to have gotten progressively worse. I'm getting a bit of back firing now when coasting and occasionally on up and down shift. It's always popped etc under heavy braking etc but now its letting out a few big bangs. Replaced the coil to eliminate that, no difference.
I'll throw timing light on it tomorrow and check that. What am i looking at timing wise, 38 degrees total timing seems to be the consensus.
Spoke with Weber Performance and they seem to think its running lean in the top end or its running rich on the idle side and leaning out when it hits the mains.
I just don't understand how it could be so far out of whack considering it was driven maybe 2 or 3 times over a mth or so. And nothing was touched at all and was running like a gem before.
