I have the exact same problem with the same SSBC kit and my brakes do not lock up. She does, however, pull up o.k (not what I would call great, though).
The disc / drum cars had a distribution block with a built in 'residual pressure' valve to keep 7-10psi in the rear lines to eliminate 'take up' on the rears. Some cars that have had unusual conversions (like falcon / granada) have had these valve removed and the take up on the rear greatly affects the stopping.
To see if this is an issue, drive a short distance with the hand brake on a bit and see if it pulls up A LOT better (mine did). If so, you may need to fit a residual pressure valve to the rear circuit. You'd think those drums on the back shouldn't make much difference, and that the car should pull up fine on front discs only, but it makes a big difference.
