petronix ignition
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
petronix ignition
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: petronix ignition (Read 2655 times)
whitehorse
Pony
I'm new here
whitehorse
petronix ignition
on:
September 18, 2015, 08:38:28 pm »
Hi all looking at fitting a petronix igniter to my 66 fastback has a 289 with standard ditsy, repro yellow top coil, 2barell etc... want to keep it all period correct has anyone had any experience, do I buy igniter 1 or 2.
Logged
barnett468
Cobra
barnett468
Re: petronix ignition
Reply #1 on:
September 19, 2015, 05:42:29 am »
The Pertronix I is fine as long as you don't leave your key in the run position with the engine off.
If you have a huge cam, you would benefit from the III unit or an MSD 6 BOX.
Also, you could likely benefit from recurving your distributor timing which can easily be done by buying a set of mr gasket springs p/n 925D and removing only the stiff/heavy spring from the distributor and replacing it with a mr gasket one.
then put your mechanical advance in the slot that has numbers between around 10 and 12.
Logged
66 Hertz
Web Editor
Top Streeter
SA member #787 MOCSA
66 Hertz
Reply #2 on:
September 19, 2015, 09:14:09 am »
have a read up here..............
http://www.mustang.org.au/forum/index.php/topic,12079.0.html
Logged
Paint by IMAGE CLASSIC CARS
build thread...
http://www.mustang.org.au/forum/index.php/topic,14043.0.html
ben73
Pony
ben73
Reply #3 on:
October 01, 2015, 01:59:18 pm »
I used a Crane XRi in my '65 FB's stock distributer. It hasn't missed a beat.
I looks stock and has the added bonus of having a built in adjustable rev limiter.
AND it won't burn out if you leave the key on to listen to the radio like a Pertronix WILL.
http://www.summitracing.com/int/parts/crn-750-1700/overview/make/ford
Logged
www.vapourblastingbrisbane.com.au
www.facebook.com/vapourblastbrisbane
mojocoops
Worked
mojocoops
Reply #4 on:
October 01, 2015, 02:35:13 pm »
I got a Petronix III all-in-one distributor and flamethrower coil, works a treat. Haven't had any issues in the last couple of years.
Logged
whitehorse
Pony
I'm new here
whitehorse
Reply #5 on:
October 02, 2015, 05:40:12 pm »
Thanks for the reply I've been away for work anyway my ditsy has been recurred at scorcher about 12mths ago
Logged
whitehorse
Pony
I'm new here
whitehorse
Reply #6 on:
October 02, 2015, 05:43:42 pm »
I think I may sit on the points set up for now as I found another battle to del with.
Logged
Print
Pages: [
1
Go Up
« previous
next »
petronix ignition
