1. you will be EXACTLY at the 2 line if you remove the fan and spacer.
2. you will loose 7 mm when you install the bolts and lock washers to hold the pulley on.
3. the condenser has absolutely no affect in traffic or below around 20 kph UNLESS the ac is on.
4. as mentioned, do NOT buy a fan based on cfm unless it is a spal or derale or maybe a davies . . buy it based on AMP DRAW . . If it draws less than around 30 amps, it is weak.
5. i was told that there are factory fans of old cars there that will fit . . the AU falcon might be one . . a factory fan will move a lot of air.
6. if you install a fan, you should install a fan controller for around 10 reasons . . these are the best.
http://www.dccontrol.com/selector.htm 7. as was mentioned, if you do not have a shroud, installing one will help greatly and.
8. if you have the big water pump pulley, installing the smaller one will help a little.
9. if you fan has 5 blades or less, it sucks . . a flex a .lite p/n 1717p will flow more air.
http://www.summitracing.com/parts/flx-1717p10. you need at least a 180 thermostat.
11. if your fan is more than 30 mm from the radiator, you are mainly sucking the air from between the blade and the rad . . you are sucking less thru the rad than you could.
12. if your ignition timing is too low, it will tun hotter than kit should.
13. If you use waterless coolant, get rid of that crap . . it will run hotter with it.
13. Any other questions?
