I added to your last post about the pedal when pumped and a few other things. I should of mentioned that. My bad. The car will stop eventually but if someone walked out in front of me 60mtrs away and I'm doing 60kph there dead.
ok you have air in your lines or your rear brakes are way out of adjustment.
the rear brakes need to be adjusted until the drag then step on the pedal and adjust them until they drag again then back the adjustmant off 1/2 of a turn.
you shoould have a regular proportioning valve, not that wilwood valve by itself.
if your brakes dont work well once the air is gone you can install front calipers with bigger pistons if you cant find a smaller master . . you could also cheat a little and relocate the brake pin on your brake pedal upward around 15 mm . . the brake pedal pin mod is the best option in your case providding the brake rod is either currently perfectly horizontal or it runs uphil from the brake pedal . . this mod will increase your pedal traavel by around 1 inch.
if your rear brakes are not adjusted tight enough, adjusting them will reduce pedal travel.
also, installing 2 lb residual valves in each front brake line will reduce pedal travel by maybe 8 mm inch.
the more you can reduce pedal travel with these changes, the more room you have to increase it by changing the leverage ratio of the brakes . . leverage ratio and brake pad mateerial is everything.
if you have cheap rear shoes you neec ebc green there alsoo . . if your rear drrums arent perfectly smooth you need to surface them.
if you do all these things it will seem like you almost have power brakes.
