what oil to use ?
Author Topic: what oil to use ?  (Read 4522 times)
Offline 65gtfasty
what oil to use ?
« on: August 21, 2015, 12:23:16 pm »
Hey
I have a new ford racing 302 crate engine in my mustang (with twin paxton superchargers attached) and am wondering what oil would best suited its just a street car , no racing for the moment . Theres so much out there mineral oils synthetic oils no zinc heaps of zync all abit confusing!!!! Any help would be greatly appreciated.
Rhys
Offline boofhead
Re: what oil to use ?
« Reply #1 on: August 21, 2015, 11:01:04 pm »
Assuming it is run in.
Mobil 1 5w30
Offline 65gtfasty
« Reply #2 on: August 22, 2015, 09:49:24 am »
Yer they come run in already , although will run it up for half hour on tun in oil and then dump it and put some new oil in.
Rhys
« Reply #3 on: August 22, 2015, 08:22:53 pm »
Just drive it and get some pressure on the rings it will be a roller cam so just get in and drive it.
Offline 65gtfasty
« Reply #4 on: August 23, 2015, 09:43:47 pm »
What oil to use shaun?
Rhys
Offline 6R07K
« Reply #5 on: August 23, 2015, 10:04:55 pm »
Been running Penrite HPR30 in my Ford Racing 302. Engine isn't doing a lot k's or pushed like yours.
Ben
Lifes short, play hard.
Offline 65gtfasty
« Reply #6 on: August 24, 2015, 08:14:52 am »
Yer was thinking penrite HPR5.
« Reply #7 on: August 24, 2015, 06:39:46 pm »
What oil do they spec for the blower? I'd probably run  penrite 10 in it or a castrol edge, Mobil is no as easy to get as it used to be.
Offline boofhead
« Reply #8 on: August 24, 2015, 11:04:23 pm »
Just a FYI - My last lot of Mobil 1 I used ebay to get my last 16 quarts - saved some money and made it easy.
Having said that most modern oils are more than adequate though in my view Mobile 5w30 is the best.
Offline 65gtfasty
« Reply #9 on: August 25, 2015, 11:16:22 am »
The blowers dont run on the engines oil , they run on there own oil.
Rhys
« Reply #10 on: August 25, 2015, 05:43:59 pm »
Rhys
Oh ok some of the Paxtons use the sump oil, you feed them via the oil sender pressure take off and run a return to the sump.
Offline 65gtfasty
« Reply #11 on: August 25, 2015, 08:14:05 pm »
as its dry sumped to will be needing somewhere between 10-15L of oil per oil change .......
