Can anybody reccomend alignment shops who deal with classics in melbourne? Ive tried couple local places however advised they had no experience with old mustangs.
Just have them set your specs to this if your roads have just a little crown to them.
CAMBER - negative .3 to .4 . . Do not use more than that unless you are racing it because your tires will prematurely wear on the inside
TOE IN - 3/16 . . Do not set it to 1/16" unless you have all heim joints because it will go toe out at higher speeds when the suspension flexes.
CASTER - positive 2.5 . . You do NOT "need" more than that for a street car irregardless of what anyone tells you, however, you "can" run more than that of you want but it makes the car harder to turn . . Nothing is free, there is ALWAYS a trade off of some kind.
If you want greatly improved cornering, just lower your upper control arm 1" like the Shelby's . . This will also lower the front around 1/2 inch.
