Thanks Mate,
Won't get a chance to do most of that until Sunday, but here are the answers I know (as I've tried most of this in the testing and tuning process)
I looked at the photo and that smells like some chinese made parts to me.
I'm pretty sure they're MBM parts, made in the USA (North Carolina, not that that's much better than China!) 1. remove the vacuum hose to your distributor and plug it.
Will do ASAP and report back2. loosen the distributor bolt 1/8th of a turn.
Will do ASAP and report back3. check and post the timing at idle.
Approx 10-12 BTDC (markings not so clear any more, I set it there deliberately it just pings a touch carrying 4 people and luggage if I flatten it up a steep hill, so I can't really go any more)4. rotate the distributor clockwise until the timing is 4 more degrees advanced and listen to see if the rpm increases . . if it does, AND the engine still runs smoothly, leave the timing there, then reduce the idle speed to normal and check engine vacuum.
Didn't advance it further because of the pinging, but at the current setting, the idle screw is right out and idle is normal (650rpm-ish).5. set both fuel mix screws until you reach the highest/smoothest idle, then reset idle speed and check engine vacuum.
This is how I got it to 13"hg in the first place, it was about 11-12 before I did that, and I couldn't get it any higher while tuning. Car was idling at 1100 at the time, will check again now I've got it idling at 650.6. remove the master and check the play between the booster rod and the master piston . . this is friggen hard to measure without proper tools but it MUST be done . . this clearance should be around .015" or around .3 mm.
When installing, I adjusted this. I couldn't get it precise (not the right tools), bit it doesn't quite touch until you hit the pedal. it's definitely less than about .5mm, but not touching at all.7. sit in the car with the engine off and pump the brake pedal and tell us if it pumps up.
Will do ASAP and report back8. remove and plug the vacuum to the booster then try the brakes to make sure it is working . . if its working, reconnect it
Will do ASAP and report back9. drive at 50 kph, then put the car in second gear, remove your foot from the gas, and mash the brake pedal and tell us what happens.
Will do ASAP and report back10. pull the emergency brake out until it stops then let it in 50 mm and see if the brakes improve or pedal travel changes . . do not drive over 50 kph or farther than 1 kilometer like this.
Will do ASAP and report backplease answer ALL of these questions one at a time.
how far does the pedal travel until it stops moving towards the floor?
Will measure ASAP and report backhow far away from the floor is the pedal once it stops moving?
About 20mmhow far from the floor is the pedal without your foot on it ie, is it stick height or closer to the floor than stock?
Will measure ASAP and report backwhat brake pads and shoes are they?
Front - The ones that came with the SSBC caliper kit Rear- not sure, a mate got them in the US, from NPD, I believe.are they new?
Yesdid you turn the drums and rotors?
Drums - Yes, Discs - No (New RDA discs with the 'bedding in' coating)do the rears or fronts ever lock up and if so which ones do?
None at the moment. Will try once I've done the other stuff you mention and report backwhat is the size of the master cylinder piston?
Not 100% sure, I didn't measure, the company makes 1" and 1 1/8" bore, but I'm not sure which one he supplied. I'll ask.what type of brake fluid is it?
Castrol Dot 4 protector seriesexactly which cam is it or what are the specs?
Don't know, engine builder can't remember exactly. He thinks it's on old school equivalent of about a stage 2, whatever that means.
do any of your brake lines from the master to the junction box have a loop in them?
Noare any of your brake lines higher then the middle of the master cylinder?
Without checking (I'm at work), I'm fairly certain they're notdo you have a proportioning valve?
No, I have an adjustable restrictor valve on the rear circuit to prevent rear lockups, but it is fully openedwhat did the booster and master cost you on ozzie dollars?
About $300 plus freight. (Aussie dollar was about even with US at the time)
