If we are talking ford ratio gears ford made 3.5 not 3.55 Untill 1972 and newer .Talking 9 inch its 4.11 not 4.0 , 3.89 not 3.9 , etc . Ford 8 inch was a 3.50 and 3.80 and a 3.91 ratio from 1969 on etc etc . They did make some weird ratios ,like 2.83 ,3,08 ,3.07 , etc,etc . Anyway a lot of ratios in these old mustangs have been changed for decades
. That's why by just turning the wheel once and counting the tail shaft turns is only a guide . Taking the center out and counting the crown wheel and then the pinion then dividing the too gives you the correct ratio .
