engine mount holes on windsor block
Author Topic: engine mount holes on windsor block  (Read 4249 times)
Offline aussie trev
  • you must have toys
  • Name: trevor
« on: May 26, 2015, 12:46:12 pm »
Has anybody got a block upside down .I am making a engine mount heat shield ,can someone  post the distance between the engine mount holes on the block please.( centre to centre of hole in  mm). thanks in advance.trev
Offline lukep6470
Re: engine mount holes on windsor block
« Reply #1 on: May 26, 2015, 03:30:18 pm »
I found a measurement of 7" on the interwebs.
Offline aussie trev
  • Name: trevor
« Reply #2 on: May 26, 2015, 04:00:31 pm »
thanks ,thats sounds right.
maybe someone has a spare engine mount they can measure the hole distance.
Offline 69ISH
  • Name: Rodney
« Reply #3 on: May 26, 2015, 07:53:20 pm »
I have a set of engine mounts in a box up inside my ceiling I could pull out if no one gets back to you but it will be a real pain in the a$$ for me to get to them i reckon art least 45 mins to find them and measure and then put it all away again.
If no one replies let me know and I will do it as a last resort.
I have found plenty on the internet stating the holes are 7" apart (177.8mm) but I don't know what the hole diameter is.
1972 Gran Torino Sport (Sold)
1968 Mustang Coupe (Sold)
Offline EXHAUSTED
  • Nearly retired
« Reply #4 on: May 26, 2015, 08:03:02 pm »
Bolt size is 7/16" unc
Offline 69ISH
  • Name: Rodney
« Reply #5 on: May 26, 2015, 08:14:19 pm »
So if we work on the diameter of the whole 1/16" bigger than the bolt that would make it a 1/2' hole so by rights the distance from center of hole to center of hole should be 7 1/2" (190.5 mm)
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
« Reply #6 on: May 27, 2015, 08:19:09 am »
Hi Trev . Measured the distance on a spare block and yep 7 inches from centre of holes. :cheers:
« Reply #7 on: May 27, 2015, 11:39:16 am »
Might be a good idea to slightly elongate one hole on each shield so you have a bit of wriggle room.
I got a pair of engine "legs" similar to these http://www.motofeet.com/ just so I could move engines around the garage when I was swapping them over and for some reason they fit the old 289 perfectly but I had to slightly grind a hole a bit oval on one side to make it fit the 5.0 roller cam engine I replaced it with. Only 1/16" or so but it just wouldn't fit otherwise. Go figure!
Offline aussie trev
  • Name: trevor
« Reply #8 on: May 27, 2015, 11:46:12 am »
Thanks for all the posts,Fingers crossed i will drill the holes today and try and fit it to the car.
