Dynacorn 67 Shelby Bonnet temperature specs
Author Topic: Dynacorn 67 Shelby Bonnet temperature specs  (Read 5356 times)
Offline lukep6470
« on: May 20, 2015, 12:21:55 pm »
Hi,
My panelbeater is preparing the car for paint and wants to know the specs of the repro Shelby bonnet. Specifically either the TG or HDT values for the composite materials. I haven't seen anything online about this.
Has anyone used one of these and know these specs? It is a Dynacorn 3641U
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
Re: Dynacorn 67 Shelby Bonnet temperature specs
« Reply #1 on: May 20, 2015, 02:26:31 pm »
Dynacorn have a question and answer page.
http://www.dynacorn.com/JoeParts/ViewQuestions.aspx
Maybe try that.
Offline Clubman7
  • Cruising.
  • Name: Brett
« Reply #2 on: May 24, 2015, 10:13:07 am »
See you asked Dynacorn a question but got a confused reply.
I re asked the question after googling what HDT and TG were.
No they're not Holden components.
I re-asked the question with information a bit clearer.
"Hi, My Panelbeater wants to know the Heat Deflection Tempreture, and the Glass Transition Tempreture of the resin used for the 67 Mustang Shelby hood 3641U but it isn't in the description. "
Whether they give you an answer is debatable as they might think of this as proprietary information to manufacturing the hood.
Although I would imagine if they had made enough of them they would have the process right so there was use of a stable enough resin to suit the application.
Offline Clubman7
  • Cruising.
  • Name: Brett
« Reply #3 on: June 01, 2015, 03:51:54 pm »
See you didn't get an answer to your question from Dynacorn. How does it affect the painting process?
