Guys, I ended up buying a set of mid eye rear springs at Mustang Auto Spares at Bulimba - paid a bit more then I wanted too ($375) but they were in stock and didn't have to freight them in from interstate or OS.
I have been told that the mid eye springs will set the car at 370mm from the centre of the wheel to the centre of the wheel arch.
Once this is done, then we will re-look at the front and adjust the height accordingly in order to get about a 25mm drop in the front after the front springs settle in a bit.
Under the pump to get this all done by the end of next week, as well as fitting new front disc rotors, replace the rag joint coupling (that's going to be a bitch to get too) will have to pull out the brake booster to get to it), re-installing the balanced tail shaft, bleed the brakes and a tune up. .
I managed to get in on a " Lunch & Dyno" day that's being run by the Corvette club where they dyno your car and give you a BBQ lunch for $40 on Sunday week down near Loganholme
Will be interesting to see what the Mach Vader will pull on the dyno as it sits without any other mods. I'm thinking maybe somewhere around 350hp + who knows, it might go a wee bit more ?
Will keep yas posted.
