Ok if detailing engine wouldn't the other type be better? Question as stupid as it sounds how does back of engine go onto stand ?
What Ray said.I didn't go with that sort of thing because I wanted to set the bell housing and clutch up on the engine before I put it in the car and you can't do that with those trolley stands bolted to the engine through the bell housing mounting holes. If you ended up taking the engine and trans out as a unit and want to put it back in the same way you'll need to consider this.
