If your concerned about draining it, and wanna go to the extent, here's a tip. Get some thin flexible hose and pump, like the type used in fish tanks for filtering. As you may guess, push the hosein as far as you can jiggling it around, and turn the pump on.
Alternatively, you can use a brake & clutch bleeder with the nipple attachment removed.
