235/60x15 tyres are the ones I would have on my Mach 1 not 215/70 x15 . Depends one his rim width ,but should be at least a 7 inch . Even a 235/60 can look small if the car sits high in the back . That car should go ok now ,but we still don't know what intake it is ( dual plain or single ). And what Holley carb is it ? . The 3.25 ratio is great and remember we drive at anywhere from 62mph to 70 mph (100 kph to 110 kph ) max here in Australia
yup, me too . . 235 or 245 . . the tallest and narrowest tires i have used just to get a near stock look was 215 x 65 - 15 . . i use a lot of 3.25 gears and 2000 stalls with all these tire sizes . . i always lower the cars at least 1" from stock too so they dont look dorky and dont have a lot of space between the tire and the wheel well.
perhaps if we can get him to run the 3.25 WITH the 235's he won't need to do any upgrades at all . . he will then have a 250 rpm increase at 60 mph and at least he could try it that way first, then decide . . also, as i mentioned earlier, if the tires are the correct width for the rims, it will corner a little better.
Gents, if I was starting from scratch I would be putting 235/60x15 tyres on the car, no question. Unfortunately what I've got is almost brand new 215/70 tyres on 15x7" Magnum rims and I can't afford to start just throwing stuff away. Just ditching the current tyres and keeping the rims isn't an option either as I wouldn't be comfortable squeezing 235 tyres onto 7" rims, especially since anything designed for an old car like the Mustang would probably have soft sidewalls. The cost of a new set of 15x8" Magnums plus 235/60 Goodrichs would be somewhere north of $2.5K landed and I would be lucky to get $1K for mine if I could find a buyer.
I did make a breakthrough ID-ing the carby though. Turns out it's a 570 CFM Street Avenger from the 4150 series with vacuum secondaries, Holley part # 0-80570. Is this under specced, or is it OK for the old 351W? Would love to be able to tell you what intake it sits on, but unless anyone knows where to look for markings then I have no idea. I can't even find any Ford Racing branded 4V intakes on the web to look at in order to make an educated guess.
If I was to change the diff gears to 3.25 plus get a new set of wheels and tyres I'd be looking at $3.5K all up, which is way more than I want to spend. Even then, it's no sure thing it will make much difference to the seat of the pants dyno. So unless someone wants to give me $1.5K for my wheels and tyres, they will be staying on the car for the foreseeable future.
With the highway gearing, I can't see my old girl spending too much time on the freeways and even when she does it will be a max of 100 Km/h here in the Speed Camera State. I did notice an ebay seller offering the Italian made Motive diff gears for $325 delivered - is that a good price? Guess it would still be at least a grand all up once you factor in labour and fluid...
