Shaunp, can you make me a drag link for my 66 RHD conversion? if yes how much $
I just used John's jig on the ones above, one for a car he was doing and 67 was for a car on the this forum I been restoring for the owner, but I often go and give him a hand with stuff and vice versa as he works on his own, Boofhead on the forum does likewise. So you really need to talk to John it's his stuff. The Xrays are not cheap, its about $200 per weld and there are 2 welds on a 66, The Xray guy is just near us and NATA approved so that is world wide certification, they do mostly industrial stuff like all the welds and valves for the Gas pipe lines from the mines etc, no engineer can complain about the welding if it passes gas pore test.
You need to find a donna falcon link as well for the ends. Better to get a latter link then XY as you cant buy XY idler arms now, XA-XF have a larger pin that goes in the idler. Power 66 link is ok cause you cut the ends off them anyway, the one above is a power one as it has the ram hole in the middle. Takes a while to weld them, to do them correctly you weld each joint about 3 times over about a 40mm area, in V shape, grind flat, dye check for any flaws then keep going till you have built it to correct height, the weld would be at least as strong as the original link, as the grain in the metal a laid down several times in layers. There is no issue with them ever failing
