Hey guys,
I know these sorts of things are always a long shot, but just seeing if i can come up with any ideas that I haven't thought of already.
Background - 289 with edelbrock performer rpm manifold, HEI dizzy, msd wires, new plugs, extractors/exhaust, summit 600 carb, carter electric fuel pump(replaced fuel tank, sender, fuel lines to 3/8th lines when I put the carb and fuel pump on a couple months ago) alloy radiator/thermo fan, plus some more. Was running perfect for the last 4 months since new carb and fuel system.
So, yesterday I installed Flowkooler water pump and stewart high flow thermostat as I was having a few overheating issues ONLY when using a thermostat and ONLY at low rpm driving(different story altogether
), plus when i pulled the water pump off when i did the front crank seal a few months ago it looked pretty sad.
While I was at it i did a flush of the block and radiator using some coolant flush, let it run for a bit, drained it all, then back flushed it with a hose till everything was flowing clear. Installed the new pump and thermostat, refilled it with coolant and started it up. Everything seemed to be running fine, just as the thermostat opened I decided to take it out for a drive. As soon as i got it out of the garage, it started missing, really badly. Well it felt like it was missing, or running rich, or lean…..it was just running crap, undrivable, about 2-300rpm lower than normal and jumping around. Put it back in the garage and left it overnight.
This morning while it was cold I pulled the plugs, a couple were pretty black, cleaned them off and re-installed(only reason i did this was because the engine was cold, i didn't want to check plugs later on and burn my pretty hands). Started her up, she ran perfectly. Sweet, must have been the plugs for some reason. Anyway, as soon as it hit about 170f it started running rough again, like a switch, pretty much when the thermostat opened i guess. Funnily enough it started running rough the same time last night.
Weird. Knowing i didn't touch anything else in the engine bay, apart from spraying water everywhere, i took the HEI apart to see if there was water in it. Nope.
Checked the timing again. It was fine.
Played around with the idle screws. Seems to get a bit more stable as i go leaner, but still rough and sounds like missing, not drivable.
Next i just sprayed carb cleaner everywhere to check for leaks, didn't notice anything.
Next I was looking at the clear fuel filter near the carb, it was only half full, usually 3/4 full. As i was watching it I saw it almost empty with the engine running, so I thought, YES, i found the problem, the fuel pump. So off I went to Eagle Auto parts and got a replacement carter pump, put it in and now the filter was 3/4 to almost full when running, HOWEVER, the miss and running rough was still there. So either there is something funky going on in the fuel tank, or the original carter pump i had decided to die at a convenient time(only a couple months old).
So, Im basically stumped now. The only thing I can thing of is either the HEI is stuffed(not sure how to test), their is some funky fuel problem happening, or, the flush has perhaps uncovered a passage through a head gasket.
Any other thoughts? Just weird as it was perfect the day before, and now after the water pump and flush it is undrivable. Only other variable maybe is the hot weather over the last couple days, maybe something to do with the fuel tank/fuel pump???(clutching at straws now)
