Im running a 302 based roller cammed windsor stroked to 331 with alloy heads and a weiand blower with a 950dp.
My current fuel system is as follows: orig tank with bottom sump welded on, -8 to filter, then a holley black under tank level at rear.
Then -8 braided hose to a 35 micron filter behind the carby to a deadhead reg and then - 6 either side of the carb.
Its too bloody noisey.
Can I put a t piece just after the pump and put a 7.5psi check valve in and run to the other bung in the sump or do I have to run it to the top of the tank so the fuel can flow into tank instead off pushing in?
Or do I have to get a return style reg and run a new line?
