will a 1966 diff bolt into a 1969 fastback?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: will a 1966 diff bolt into a 1969 fastback? (Read 1915 times)
wildplum
Thoroughbred
wildplum
on:
April 20, 2014, 03:37:34 pm »
hello
im wondering if the spring saddle width on a 1969 is the same as a 1966
I think the diff overall length is wider on a '69 but if the spring saddle width is the same
then it would bolt in?
Logged
2/73. JG33 KWTB
8/1969 63C S5 Mach1
6/1965 76B 8B94
ScottW
Worked
Fence Sitter
ScottW
Re: will a 1966 diff bolt into a 1969 fastback?
Reply #1 on:
April 20, 2014, 03:54:55 pm »
You'd need custom wheels due to the crazy -ve offset you'd need.
Logged
wildplum
Thoroughbred
wildplum
Reply #2 on:
April 20, 2014, 03:56:54 pm »
yes I realise that Scott its more the concern if it will bolt straight in or would the saddles need to be re located
Logged
2/73. JG33 KWTB
8/1969 63C S5 Mach1
6/1965 76B 8B94
big al
Worked
big al
Reply #3 on:
April 20, 2014, 05:12:46 pm »
You will need to use the 65-66 saddles and U bolts also.
Logged
http://bigalsmustangs.com.au/
GLENN 70
GT 500
GLENN 70
Reply #4 on:
April 20, 2014, 06:09:44 pm »
As said above ,they just bolt in .But remember they are 2 inches narrower 57 1/4 inches compared to 59 1/4 inches ,so your wheels will need a nice outside dish .
Logged
shaunp
GT 500
shaunp
Reply #5 on:
April 21, 2014, 08:07:58 pm »
Got a Versailles 9" disc rear here would be a closer fit I think.
Logged
yamahore
Thoroughbred
I'm new here
yamahore
Reply #6 on:
April 21, 2014, 10:24:01 pm »
Dish is good
Logged
Print
Pages: [
1
Go Up
« previous
next »
