I am considering converting my 65 to RHD , there is much to research beforehand. one is weather some of the modern AC will fit.
i had found a few different brands and sellers of A/C units, the AC's that replace the heater box sound like they work far more efficiently than reconditioned original units or reproduction of the same with added benefit of also heating (are they true 'climate control'? as in what fairlanes etc use from the 90's on, where you set a temp (in degrees) and basically just leave it alone. i'm not sure i see that provision on these units but none the less i assume they are effective units. i had a bunch of pages open for all the different brands but i've lost them now, arrg!. however i think i read somewhere that at least one of them would not fit in a RHD converted car? not sure which brand it was now (although the basic behind dash box appears much the same on all of them but i did see some paragraph where one brand/maker (at a guess vintage air) offered to customise to some degree, i remember reading something about if the firewall was flat or not they could make one to fit.
there are lots of people with converted RHD 65's around so i thought perhaps some light could be shed on it..
