Hi folks
I installed my dakota digital VHX dash today and everything works fine except the speedo.
Im running a 4 speed.
The dakota kit came with an adapter for the ford transmission.
so,,, i removed the speedo gear from my old speedo wire and put it on the dakota ford adapter, then screwed in the electronic pulse generator (16KPPM), and mounted it to the transmission.
everything fit well.
Problem, when I try to calibrate my speedo, I drive one (1) mile and with a press of a button it should be calibrated. But, it seems that the speed sender is not picking up pulses as quick as it should. but anyways, eventually I picked up the minimum number of reading required to calibrate the speedo (2000 pulses) and saved the setting so I can go into a manual adjust mode - but didn't have any luck with that either as it seems the sender is not sensing enough information for calibration to work.
its a 16K PPM sender, but after driving around for what seems to be a few minutes i eventually pick up a few thousand readings. so this would NOT be enough. also when it detects the pulses from the sender its a bit erratic (i.e., slow, then fast and a random combination of the two) so this leads me to believe something is slipping mechanically in this sender and adapter. even without the speedo calibrated, my needle jumps erratically from one speed to a higher speed etc and vice versa.
I pulled everything out, checked the plastic speedo gear and it seems fine, doesn't look worn out plus its only a few months old and worked ok on my stock speedo with a speedo cable.
Im now thinking that its the actual dakota speedo sender that might be the issue, or its ford adapter to fit the transmission and maybe the marriage of these two is causing some play and some slip.
I was at it all day and eventually gave up and got hungry.
has anyone had or experienced such an issue like this with the dakota kit?
