If that's what the site says then it's an etch or at least a self etching primer ( most epoxy's are) it has to be if it will stick to alloy and Gal with no other etch. Particularly gal. So scuff it up, blow it off with air and a cloth, I use Supa cheap microfiber towels, as you can just wash them and they pick up most dust, use some wax/grease remover etc and paint it. If you have the cleaners they say, make sure, they don't dry on the panel ie as they say don't let it flash off.
