I need to build a pump for a Boss 429 and need the lever out of an old pump - it's the steel bit sticking out of the body that runs on the cam shaft eccentric - the one I need is specific to a Carter or Holley pump for a 385 series motor (429 or 460) so if you have an old knackered (or good but un-needed) one, then please drop me a line....
It should look like this:
