289 Oil Pan with Provision for Dipstick
Author Topic: 289 Oil Pan with Provision for Dipstick  (Read 1766 times)
Offline Wharfie66
« on: December 05, 2013, 08:25:14 pm »
Hi There,
I have a '68 289 windsor motor that I am putting in my 66 coupe and I need to use an oil pan that has provision for a dipstick.  I am using a March Performance serpentine kit which uses a later timing chain cover/short water pump setup from later builds that does NOT have a dipstick provision or boss on the timing chain cover.
Can anyone recommend a good oil pan with dipstick provision that fits this 289 windsor?  Any help is greatly appreciated.
Fletch
Fletch
Re: 289 Oil Pan with Provision for Dipstick
« Reply #1 on: December 05, 2013, 09:28:33 pm »
Canton racing street pan about $245 from Summit, dip stick to suit about $20. Or one from and EA EB falcon should be ok I think
Canton is a street race pan, holds extra oil, baffled and has a crank scraper. Gold anodised
« Last Edit: December 05, 2013, 09:30:05 pm by shaunp »
Offline Wharfie66
« Reply #2 on: December 05, 2013, 11:23:48 pm »
Thanks for that ShaunP, excuse my ignorance, but would I have to buy a new pick up as well? I assume I would.  I already have a lokkar steel braided dipstick which I may have to recalibrate, I think it should fit. Also, if I was to get my motor rebuilt to a 347 (it is actually a 302 block) is this pan suitable? Thanks again.
« Last Edit: December 05, 2013, 11:33:07 pm by Wharfie66 »
« Reply #3 on: December 05, 2013, 11:30:22 pm »
Yep I think it is about $40 for the pickup, sump is $243
sump part number is CTR-15-610
pick up is                  CTR-15-611
« Reply #4 on: December 05, 2013, 11:33:24 pm »
Link to sump at Summit, pickup is in the side bar of recommended parts.
289 and 302 are basically the same block, 347 is built in either a 289 or 302 block no issue. The sump will take a 3.4" stroke max which is 347.
http://www.summitracing.com/dom/parts/ctr-15-610/overview/
« Last Edit: December 05, 2013, 11:46:34 pm by shaunp »
