!2 volt switched power
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: !2 volt switched power (Read 1426 times)
skev
Blue Printed
skev
on:
November 20, 2013, 06:42:16 pm »
where's the easiest place to take 12 volt switched power south of the firewall on a 67 do you think? The ignition switch?
Logged
67 Convertible
unilec5544
Worked
unilec5544
Re: !2 volt switched power
Reply #1 on:
November 21, 2013, 12:44:53 am »
That depends on what you need it for and what amps you will draw, there is only so much current can be handled by the contacts in the ignition switch. if you need a lot of amps, just use the switch to operate a relay or contactor.
Logged
ScottW
Worked
Fence Sitter
ScottW
Reply #2 on:
November 21, 2013, 09:15:35 am »
If you are handy with electricity, your best bet is to install a new feedline from the battery to a fused distribution block on the firewall somewhere powered up by a relay hooked into the ignition. Also run a 40 amp circuit breaker on the new feed line in case of shorts. You can get the bits you need from Narva or the like.
Then you will have a few switched power sources should you need them.
Logged
skev
Blue Printed
skev
Reply #3 on:
November 21, 2013, 09:39:18 am »
what I am doing is replacing my ammeter with a voltmeter. So according to the instructions it needs a 12 volt switched source and an earth. I cant imagine it would draw much power?
Logged
67 Convertible
skev
Blue Printed
skev
Reply #4 on:
November 21, 2013, 10:46:53 am »
I see now from looking at some pics that there's supposed to be a 12 switched post coming out the back of the ignition switch, that also works on ACC. I guess if I use that I can tell when the radio is causing the battery to go flat.
Logged
67 Convertible
Print
Pages: [
1
Go Up
« previous
next »
