Hi Pash,
6mm is too big
What headlights are you running?
4mm will give you around 15amps
Most decent headlights will need around 8amps, so 4mm is plenty.
If you want to go bigger
just get the 5mm from Narva, it will handle 25amps
page 238 of the Narva 2013-2014 catalogue
part number 5815
comes in 30 or 100 metre roll.
Just so you know what I did to my '66
I kept the original fuse box to run all the standard electrical in the car
and then ran a new Narva 54426 Blade Fuse box which comes with 2 inputs
I split the 2 inputs so you can have 2 circuits running
1 input- as always on (Live)
1 input- as switched with ignition/accessories using a relay
I then ran an 8 B&S wire from Narva catalogue number 5808M-30RD rated at 100amps
direct from the battery.
The new fuse box is in the console which I custom made
and accessible through the side panel
I also re-routed all the wiring in the engine bay through the inside of the guards so there are no wires in the engine bay.
Now it looks tidy.
All of my new accessories run from the new fuse box
and are switched differently depending on their need for example:
AO - means Always on
SO - means switched on with the accessories
SO - Retro Tacho
SO - Thermo Fan
SO - Electric Windows
AO - Rear Solenoid Boot Release
SO - 7inch DVD, GPS, Bluetooth, Digital TV player
AO - Memory for the DVD Player
AO - Air Horns
AO - Central locking, still need to install just haven't had time
Hope this helps
Any questions
give me a call
Mob: 0414 911 171
Moz
http://i1184.photobucket.com/albums/z337/ozstang/DSC02262_zpsd75cec16.jpg
