Anyone out there had experience with the manual reverse lockout shifter?
I am thinking about adjusting the angle of the shifter so it points towards the RH driver to shorten the arm stretching required to get it up to first and third gear.
Is it possible to dismantle the lockout lever and remove the cable?
Can I cut and re-weld the shaft without heat damaging anything inside?
PT
