Something like that, I've got a Crane Hi6 cdi for it so I thought I'd set the rev limiter in the hi 6k range, The cam is supposed to go to 6K but it's a 351 cam, so it will go a little higher in a smaller engine, all the bolts are ARPs, rods, main studs etc, should hold together ok. Need some lower dif gears, but I'll see how it goes first with the 3.0 rear then decide what to buy fit True track at the same time, I've put Traction masters on it, but it will still turn the tyres for sure, as I've got Firestone Wide Ovals F70 x14's for cruising, I'll get some Hoosiers for Mt Cotton and sprint days on some other rims.
