thebirdman, no wrong you are doing 2500 revs .Either your taco is out or you have 3.5 ratio diff .You can check your diff ratio sort of, by jacking up the rear end ,marking the tail shaft then turning the wheel or both 1 turn, counting the tail shaft turns ,now you have to do this very slow as the tail shaft will spin very fast. eg. 1 turn with a 3.00 will be 3 turns ,a 3.25 , 3 1/4 turns ,a 3.5 ,3 1/2 turns
