My Mustang Improved Production racecar
Author Topic: My Mustang Improved Production racecar  (Read 3047 times)
Offline Barney
« on: May 03, 2013, 04:06:25 pm »
Hi All
I am in the process of importing a Fox body Mustang for circuit racing. Currently its on the water, should see it in about 3 weeks.
Managed to source a engine for it, that is in transit from Georgia. Currently it has fitted a fresh built/forged 302 with alloy heads which I will be selling, let me know if you are interesting in buying the engine??
Currently it has a cage, race seats, Tremec TKO600, decent brakes and some other cool racing stuff. I will be stipping it down and getting it on a rotiseerie asap, then adding to the cage, upgrading the brakes and later adding a Holinger Dog box
With a bit of luck it will see the track in 2014.
Engine details
363 CI SBF 5.0 BASED ENGINE
4.100 BORE
3.450 STROKE
FORD MOTORSPORTS R302 BLOCK
8.2 DECK HEIGHT
4 BOLT MAIN SIAMESE
BRYANT BILLET CRANKSHAFT
CARILLO RODS
5.450
3.0 TOTAL SEAL RINGS
.912 WRIST PINS W/ROUNDWIRE LOCKS
CLEVITE 77 BEARINGS
YATES C3 HEADS
PORTED BY ROUSH RACING
A36 SPS BOLTS
PRESSURED OIL PINS
CP FLAT TOP PISTONS (EST 13.5.1 COMP)
1.5 BEARINGS
FULL ROLLER CAM BEARINGS
CRANE ROLLER CAM 262/715
 CRANE NASCAR CHAIN SET
JESEL 4130 PUSHRODS
FELPRO HEAD GASKETS
ARP MAIN AND HEAD STUDS
BLUE PORTED BILLET DISTRIBUTOR AND HOLD DOWN
MELLING HV OIL PUMP
4130 PUMP DRIVESHAFT
MOROSO OIL PAN FOR FOXBODY MUSTANG
1.65 RR'S
TITANIUM VALVES AND RETAINERS
CROWER SPRINGS
TRICKFLOW 3/8 VALVE COVERS
W302 FORD MOTORSPORTS INTAKE BY WILSON MANIFOLDS
CUSTOM HOLLEY CARB BY (THE CARB SHOP)
Here are some pics
Ash
« Last Edit: May 03, 2013, 05:40:11 pm by Barney »
