thanks guys for the response's. i want the car as a daily driver. i was looking at rrs conversion kit. i know its dearer than cutting up the original firewall dash ect. however it appears that it would be a whole lot easier and a better job. whta are your thoughts? oh and how much for an engineers certificate.
thanks
As for the Dyna corn stuff, the firewall is just flat, this limits the use of AC which is intergrated in 67 on, cars,they need the hump in the firewall to fit the AC, you could use an early falcon heater box though with no AC as Falcons have a pretty flat wall. Dash would be ok, but the dash is not that hard to do, other than the plastics. The other issue with Dyna corn fire wall, is it kind of assumes you will use the LHD pedals etc which is not the best way to do it, better to use RHD falcon units, as the pedals are bent correctly and end up in the right spot. The plenum would be ok, but only if you were swaping it out due to yours being rusty, again not that hard to shift the wipe mounts. Don't think Dyna corn make pre67 RHD metal either.
