Author Topic: What did you do for your Mustang today?  (Read 658517 times)
Offline Tonyobris
« Reply #550 on: September 08, 2013, 10:05:07 pm »
Big weekend, new radiator ready for summer, new voltage gauge, and then new one wire alternator to keep the power up.. Test drive his afternoon was fantastic...   :grin:
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #551 on: September 08, 2013, 10:53:33 pm »
The product is from Parker I will get some details and post,
It is nothing like extractor wrap.
It is used in the Fire Service industry to protect Fire truck fuel and brake hoses.
In is in tube form from 15mm id to 130mm id. ( I still have to fit stainless steel cable ties, run out at the time )
Transmission is a BTR electronic 4 speed.
Peter.
« Last Edit: September 09, 2013, 02:32:16 pm by peter9231 »
Offline Red67Coupe
  • Restored
« Reply #552 on: September 09, 2013, 10:18:19 am »
Peter.
Hey Peter.  It would be interesting to get some specs on it, like how much heat it can tolerate.  Might be something for the common problem of power steering hoses running close to extractors. :flaming:
Ken
Offline peter9231
  • Name: Peter
« Reply #553 on: September 09, 2013, 02:31:36 pm »
Hello,
It is rated at 260 degrees in direct contact and up to 1100 degrees at intermittent exposure.
So if it was a couple of inches clear of extractors it would survive.
We have tested fire appliances at 1000 degrees radiant heat load with no problems.
Its not cheap though!
Will post some more details later.
Peter.
Offline peter9231
  • Name: Peter
« Reply #554 on: September 09, 2013, 08:09:07 pm »
Here's a couple of more photos of the tubing.
The AS number refers to an aviation heat protection rating for electrical and hydraulic loom and hose protection.
I will track down the supplier and advise when I return to the office.
Peter.
Offline Mustangpaul
  • Look before you leap
« Reply #555 on: September 10, 2013, 10:08:49 am »
My electrical is sorted, it's full steam ahead again.
1967 Mustang Convertible with fries and the works, hold the rust, no timber thank you, go easy on the Bondo and I'll have that in Right Hand Drive please.
Offline JT_1994
« Reply #556 on: September 10, 2013, 01:39:13 pm »
Ripped the heater box, core and fan out today..
Figured I could get at least half the job of fixing the heater done before my classes tonight..
It only took a few hours, I will replace the fan and put it all back together on Thursday morning.
Should have a working heater/de-mister by the weekend, so I will be able to get a roadworthy inspection booked for early next week and hopefully have the car inspected by the club so I can get it rego'ed in a week or two! :pepper:
Before.
.... After.
Amazing what a fresh coat of paint can do!
I also found that my floorpans are even more solid than I thought, with only a little surface rust in the corner!
« Last Edit: September 10, 2013, 04:22:57 pm by JT_1994 »
JT_1994 aka "Nixon"
Offline birdman
  • Name: John
« Reply #557 on: September 10, 2013, 09:30:22 pm »
Refitted my console and seat back in. Shifter is nice and tight without rattles.
John
Offline Moz
« Reply #558 on: September 12, 2013, 05:38:58 pm »
The Joker got a new Tinted Windscreen today.
He is very happy
Moz   :pepper:
Offline JT_1994
« Reply #559 on: September 12, 2013, 06:14:14 pm »
After many hours of pain and suffering, I eventually got the heater fan motor working and circulating air to the windshield so I can get a roadworthy certificate Tuesday morning.. :pepper:
JT_1994 aka "Nixon"
Offline Moz
« Reply #560 on: September 12, 2013, 08:40:02 pm »
Does the heater come in as part of the RWC?
Moz
Offline Macka
  • Vic member 1571
« Reply #561 on: September 12, 2013, 08:42:11 pm »
Moz
Yep it will, demister needs to be operative...
Offline Moz
« Reply #562 on: September 12, 2013, 08:59:37 pm »
ok
It's just that I don't remember seeing it being looked at,
maybe I just didn't notice.
Moz   :shrug:
Offline Mustangpaul
« Reply #563 on: September 13, 2013, 09:37:54 am »
I dropped the cragars off to the mechaninc this morning, I can't wait to see them fitted. Today the mechanic will do the video of everything working for the inspector to issue the compliance plate, then the car shall be ready for the rego. In case you cant guess I am a little bit excited right about now. It has only taken me 2 years 7 months and 13 days (hours are confusing because of the time lag between Australia and the States)  so far.  :evilone:
Offline scedd1
  • Name: Steve
« Reply #564 on: September 13, 2013, 12:05:59 pm »
Then why the f%&k would you try to rego it on Friday the 13th?
Who knows what could go wrong today :lmao: :lmao: :lmao: :lmao: :lmao: :lmao:
.  ____________
./____________ \.
 ( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
 |___|            |___|
Offline Mustangpaul
« Reply #565 on: September 13, 2013, 03:39:05 pm »
Hello Scedd,
if you followed my posts to date, every day is Friday 13 and the fianl date to get it in the road is 12th, that is 12 of Never.  :toetapping:
Offline Rock65
« Reply #566 on: September 13, 2013, 07:15:42 pm »
After 6 months of not doing anything to the car( bit burnt out) got on line and order heaps of goodies,went out and bought some new leaf springs and took the cover off to access what to do next. New motivation has arrived, and should get a good run at the resto the next few months.
Offline Mustangpaul
« Reply #567 on: September 13, 2013, 07:31:17 pm »
Stay focused, here is what mine looks like now, we'll finish it off on Sunday and I should be on the road next week.
« Last Edit: September 14, 2013, 12:43:49 pm by Mustangpaul »
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #568 on: September 13, 2013, 08:20:47 pm »
Your car is looking fantastic mate, hope it all goes well for rego ,just in time for spring / summer cruising  :thumb:
Matt
Offline Raven
« Reply #569 on: September 13, 2013, 10:20:10 pm »
tube nuts and letters on the bonnet and boot lid.
Offline 73 1of2
  • Name: Markus
« Reply #570 on: September 14, 2013, 12:18:13 am »
Looking at the calendar with what date next rego runs out,, its close now:) :omg: winters almost done :smilies:
« Last Edit: September 14, 2013, 12:21:52 am by 73 1of2 »
Life It's as good as you want to make it and a mustang makes it great
Offline JT_1994
« Reply #571 on: September 14, 2013, 12:28:41 am »
Nice looking car, Mustangpaul! :thumb:
I'll be taking mine to get a roadworthy inspection done Tuesday morning, hopefully I can get it rego'ed later next week.. I've been through the list a dozen times and I can't think of or see anything they could pick up on that would make it unroadworthy.
I even gave it a polish and vacuum yesterday to be sure! :grin:
JT_1994 aka "Nixon"
Offline chopmgw
« Reply #572 on: September 14, 2013, 12:52:56 am »
Let me be the first to wish u luck next week Mustangpaul , u probably deserve some after your resto.
I can just see u now, cruising down the road with them old dogs in the back !
Car looks great. Well done.  :thumb:
I can smell oranges !
Michael
Offline Mustangpaul
« Reply #573 on: September 14, 2013, 11:30:30 am »
The dog in the photo wants to pee on my front wheel, if the yard did not belong to a friend of mine I'd probably rig an electric shock to that wheel so when he does pee on it the shock would go up his stream and zap his little doodle. Why do dogs have to pee on wheels? At least if a dog is going to claim territory, peeing on a Mustang shows good taste I suppose.
Offline Mustangpaul
« Reply #574 on: September 16, 2013, 12:33:07 pm »
My mustang is booked in a t Bob Jane today for the wheel alignment, then when the compliance plate arrives it is off to DMT and I'm on the road.
