Author Topic: What did you do for your Mustang today?  (Read 658127 times)
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #500 on: September 02, 2013, 07:28:16 pm »
Had a bit more time tonight set timing and tuned the old girl.
Balances a 50 cent coin when running so all is good.
Peter.
Offline JT_1994
« Reply #501 on: September 03, 2013, 01:35:52 pm »
Got it out of the garage and gave it a polish..
Nice and shiny now! :drool:
Such a shame I can't drive it, but the heater doesn't work... (It's unroadworthy and unregistered) :ouch:
JT_1994 aka "Nixon"
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
    • http://s731.photobucket.com/albums/ww313/ozzyone_photos/66%20GT350H/?albumv
  • Name: Dale
« Reply #502 on: September 03, 2013, 01:44:15 pm »
wont be too much longer JT.......... :thumb:
Paint by IMAGE CLASSIC CARS
build thread...http://www.mustang.org.au/forum/index.php/topic,14043.0.html
Offline JT_1994
« Reply #503 on: September 03, 2013, 01:59:46 pm »
Yup! Just got to fix the heater and I'll take it for a roadworthy..
Who needs a heater when it's a comfortable 24 degrees and the sun is shining though? :bolt: :lol:
JT_1994 aka "Nixon"
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #504 on: September 03, 2013, 02:26:25 pm »
I'm at a loss, here. Why does the heater have to work for a roadworthiness cert? When I bought mine from Vic, the heater didn't work, in fact it wasn't connected.
Good luck getting it regoed, JT and I like the scoop. V cool.
cheers, Ron B
Offline 68Coupe
  • MOCA NSW Member
« Reply #505 on: September 03, 2013, 02:43:34 pm »
Hey JT, the car looks great. Love the colour.   :thumb:
Offline JT_1994
« Reply #506 on: September 03, 2013, 03:02:51 pm »
cheers, Ron B
Thanks Ron,
It came out better than even I thought it would with the scoop and pins..
Gives a great view out of the driver seat and looks mean coming down the road. Plus the motor gets a bit more cool air too! :pepper:
The heater has to work to be able to defrost the windshield on cold days..
To be honest, I think it's a bit silly that I need a heater / defroster, considering it's an old car.. :bolt:
It sleeps in the garage where it's safe and dry, so the windshield can't get iced up and if it were raining, it wouldn't be going out at all!.... But it's a roadworthy requirement, so I've got to fix it.. :ouch:
:agree: The guys did a great job with it.
It looks awesome with the clear coat and it's so smooth, no dirt or orange peel, so the micro-fibre cloths just glide over it!
JT_1994 aka "Nixon"
Offline jaythefordman
« Reply #507 on: September 03, 2013, 03:06:13 pm »
Got let out of the doghouse over the weekend, and so I managed to change out the old headlight switch for a new one and clean up some more wiring under the dash.  Was good to have a win for once :)
Offline IGALOP
  • Pegasus
  • I have "CRAFT" Can't remember any F'n thing.
  • Car: 2017 GT
« Reply #508 on: September 03, 2013, 03:48:53 pm »
New Carby kit and points fitted plus changed back to newer coil. Older coil had started leaking oil and old points were *$#@ed.
Timing adjusted and only need a bimetallic choke spring to bring it up to as new spec. Seems to be running well but had been murder on the gas, for a few weeks.
Let the cruising weather now dominate.  :burnout:
Johnno;
Proud Vic MOCA member # 1569
I know it seems like I am in denial.........but I am absolutely not !!
Offline 1966stang
  • Name: Greg
« Reply #509 on: September 03, 2013, 04:02:29 pm »
Took her for a cruise to Cowra and back to check the new seats (BA ute).
A lot more comfortable and easier on the back  :pepper: but the lap/sash belts are too short, will have to look at getting longer for the wife. She has to have the seat right back for it to fit. Also needs a longer drop, belt rubs on her neck. Not happy Jan.
Also on the down side, I found the AC needs re-gassing (again). Hope they can find and fix the leak, this will be their third go.
Greg
'66 C code Coupe, Wimbledon White
Was 289 now 302
Of course I talk to myself, sometimes I need expert advice.
Offline Ash
  • Name: Max Power
« Reply #510 on: September 03, 2013, 04:17:28 pm »
Ordered for my 69CJ, Scat H-beam rods with ARP 2000 bolts. Also have ARP head and main stud kits coming too.
With the order I have replacement valve stem seals and a rocker cover gasket for my 66.
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #511 on: September 03, 2013, 06:07:46 pm »
`Also on the down side, I found the AC needs re-gassing (again). Hope they can find and fix the leak, this will be their third go. `
There is a additive available for the refrigerant gas circuit used for leak detection. I once drove an early Fairmont with the same issue ,the leaks were numerous to say the least (sort of like CSI,using a blacklight)  :thumb:
With the seat belt drop to keep the wife happy, I purchased a set of of sheepskin seat belt covers that wrap around and close with Velcro,
Matt
Offline Mustangpaul
  • Look before you leap
« Reply #512 on: September 04, 2013, 04:32:30 pm »
I washed her with a rag and fresh water, just in time to get a phone call to hurry back to my office with a client waiting. I am waiting for the auto electrician to visit and then I'll be able to put the rest together and pay for my rego. the car was outside the work shop so I pushed it back inside on my own, not an easy job as it was a slight up hill climb, 2 inches at a time, constantly kicking the chocks under the wheels so it couldn't roll back again. The only thing I need now is more PATIENCE  :toetapping:
1967 Mustang Convertible with fries and the works, hold the rust, no timber thank you, go easy on the Bondo and I'll have that in Right Hand Drive please.
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #513 on: September 04, 2013, 05:37:35 pm »
[/quote]
And a winch
Offline Raven
« Reply #514 on: September 04, 2013, 09:41:01 pm »
Transported the car to the exhaust shop today. The rear end is busy, but was told it would not be an issue. Friday pickup :pepper:
Offline DUNRITE66
« Reply #515 on: September 04, 2013, 10:28:29 pm »
It has finally come home after a year of driveline work. .. From front to back.  5 engines in 4years.  Think its time to stop ...
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #516 on: September 04, 2013, 11:00:17 pm »
`Transported the car to the exhaust shop today. The rear end is busy, but was told it would not be an issue. Friday pickup` :pepper:
Must be getting excited now Dino  :thumb:
Matt
Offline Macka
  • Vic member 1571
« Reply #517 on: September 04, 2013, 11:29:45 pm »
Raven, I'd like to see the work of art when its finished, getting pipes through there..
Offline IGALOP
  • Pegasus
  • Car: 2017 GT
« Reply #518 on: September 05, 2013, 07:26:03 am »
Side exiting pipes perhaps?????
Johnno;
Offline boss69hogg
  • Name: David
« Reply #519 on: September 05, 2013, 01:19:12 pm »
Picked her up from the mechanic - again, after having an oil leak fixed - again, to drive it home and find its leaking oil - again!!
NOT HAPPY!!
Offline 66 Hertz
  • Web Editor
  • Name: Dale
« Reply #520 on: September 05, 2013, 03:21:55 pm »
NOT HAPPY!!
...............need a better Mechanic I think
Offline Mustangpaul
« Reply #521 on: September 05, 2013, 04:54:54 pm »
NOT HAPPY!!
Sometimes I have noticed a leak can disappear with use after a gasket has been installed, where is it leaking from?
Offline lukep6470
« Reply #522 on: September 05, 2013, 05:40:28 pm »
Offline my 390
« Reply #523 on: September 05, 2013, 05:50:10 pm »
Tightened the wheel cap centre that was hanging on loosely by only one thread.
Offline boss69hogg
  • Name: David
« Reply #524 on: September 05, 2013, 06:38:03 pm »
Leaking from the front of the bell housing. At least my mechanic is good. He's coming to me next to look at it - might be a rear main.
